RCU Forums - View Single Post - Building Problem
Old 12-29-2019 | 07:35 AM
carlgrover
Plans for Old School are available at Outerzone. It's a glider and boy is that fuse skinny. The plans on outerzone are a redrawn version so may not be exactly what you have on hand. I took a quick peek at them and saw that the servos are mounted in line from front to rear. It will be tough to run pushrods back to the rudder and elevator. I would recommend flexible Dubro lazer pushrods or something similar. Best to install the outer rods as soon as you get the sides and top or bottom glued together. Gliders are not my forte' so i'll tap out here.
Don't give up. Building from plans is much more rewarding than ARFS/foamies/etc.
carl
