Originally Posted by
tubig
here some shots of the wing struts. i went with the kit's plan on using screws to fasten the struts to the wing undersurface but decided it would be too tedious to use the plan's idea of using nuts and bolts to fasten the struts to the fuse so i went with clevises instead. not as scale but probably infinitely easier at the field. now i need to put some scrap balsa on the strut support wires and sand to shape. kinda burned out on sanding as it took me hours to sand the 4 spruce struts to shape.
Do you have some good close up pictures of the tail sections? I am totally lost on how that all goes together. Can’t figure out exactly hot the balsa blocks for the horizontal stab mounts in the fus. Also how the vert stab mounts.
