RCU Forums - View Single Post - CG On E-Flite Extra 300 1.3m
Old 01-03-2020 | 06:42 AM
knpjdad's Avatar
knpjdad
What size mAh is your battery? If it's 2200 that is on the lite end of the specs for this model. Maybe try a heavier 3200mAh battery and it would balance at the recommended spot. Then like ahicks said once you get past the maiden you could put the lighter battery in to move the CG back if needed. Just remember a nose heavy plane fly's poorly, and a tail heavy fly once.
