RCU Forums - View Single Post - Robart Robostruts
Old 01-04-2020 | 04:29 PM
Slimsi
Default Robart Robostruts
I do not know what these were mounted on, but they are sturdy and in great shape. Appear to be Robart Robostruts, 681 left and right. The mains are 12" long to the axle hole. Has matching forked nose wheel.
The nose is steerable and the bottom half was painted black. Could use a light sanding and touch-up on the black paint.
The nose gear is 8" to the "mounting" block (the steel device that is installed), and does rotate inside that also. The whole nose unit is a little over 12" long. The nose unit fits a 5 1/4" wheel and could accept slightly larger if needed.
For full asking price I will cover shipping and include the nose wheel.
Ask any questions you like.
You can check my trader rating on RCG under the same name.
Slimsi is offline
