Designed new turbine mounts then verified the fitting with 3D printed version. I will be machining the final version next weekend.
Original mounts
First prototype: In the manual the noted distance between the turbine bracket holes is 136 mm, in reality I measured 140 mm
Version with 140 mm hole to hole.
