RCU Forums - View Single Post - For your NPRM Response...s.
Old 01-14-2020 | 11:58 AM
  #46
franklin_m's Avatar
franklin_m
Originally Posted by grognard
- Expanded FRIA application period
- Opening FRIA eligibility to non-CBO entities and private individuals
- Allowing temporary FRIAs, for contests, airshows and other special events
- Eliminating the rule that once a FRIA is terminated, even by request of the CBO, that it can't be reestablished
- Consideration of additional FRIAs based on the distance between them (so no one has to drive too far)
- Making FRIAs a permanent part of the airspace system, not a temporary expedient
- A higher weight threshold for the UAS registration requirement, for fixed-wing aircraft flown within visual line of sight
- Provision for "modular means of compliance" -- drop-in RID compliant components that a builder can install himself. The burden of "proof of compliance" being on the MANUFACTURER, where it belongs.
I actually agree with two of those. The rest, IMO, are non-starters because the stated goal of FAA is eventually EVERYTHING will have remote id. As the first several do not ultimately lead to that goal, I believe the FAA will reject such suggestions.
However, the modular compliance is the long term solution. I can support that.
