Originally Posted by
Maxam
Hy, You do have the circular wiring harness for the plugs that came with the engine? Wire that and the ground to a robust female plug mounted in a hidden spot on the plane near the engine with the shortest wire. The external battery pack you make will have the male matching plug as well as a charging plug. -Tom
What a great idea Tom. Thanks for clairification. Not used to things being so simple in this hobby 😁
