Skymaster F-104 Starfighter
Newly built Skymaster F-104 with all the best options. This is available as a RTF model, or BNF model if you have Jeti. The jet has 14 perfect flights no it. It has never been damage. It has been painted with automotive paint and the decals are from Taylormade. The tail is removable for transport. The main retracts are air over hydraulic...and they work perfect. It also has a Detail for Scale chute system with retracting door and air operated speed brakes. It has functional leading edge flaps. The follow is a list of options added to this model.
-Unilight Professional light system
-Unilight afterburner ring
-servos are JR 9711 and 8911 (8)
-it uses 3 Jetronic air valves and 3 Xicoy valves (gear, doors, speed brakes, chute system)
-Hi flow fuel system from JMP with a kevlar hopper.
-Hi flow UAT
-Powerbox servo wire
-Ashloc connectors
- custom wingbags from Revoc
-3 air systems
-spare brakes and tires
-full body pilot and cockpit
-Jeti CB400 and a lot of telemetry , including turbine telemetry
-Kingtech K-210 with low time
-much more- too much to list
Available 3 ways
$9500 BNF
$8500 minus Jeti gear and sensors
$6500 minus Jeti and K-210
Would do a partial trade on a BVM 1/5.5 scale F-18 or a Kingtech K-320 with low time.
