RCU Forums - View Single Post - T-One Models 2.7m F-22 build
Thread
02-04-2020, 04:35 PM
96
FenderBean
Well today was another slow day the canopy install was a rough one, its hard to get the proper alignment to make the rear section clear while making the front align. When the installed bulkhead is off a hair it makes it much harder, but I got and in the pictures you will see two washers on the right side I used align the canopy. The linear servo works great and I am uploading a video going over the work so far.
I removed the stock air cylinder lock and will be using a second Actuonix 30mm stroke actuator for the lock but mine will be mounted to the nose instead of the canopy.
I have been putting off the motor install just going to be a lot of trial and error so I skipped on to some easier things.
https://www.youtube.com/watch?v=gx2o...ature=youtu.be
This is the factory lock, I removed it and will add another Linear servo
Removed a small amount of material for clearance
PAIN in the but I spent all afternoon on four screws!
Closed
Open
All the required items for the nose steering
Completed, the factory had the light bracket on backwards scissors go aft by the way
Reply
Like
FenderBean
View Public Profile
Send a private message to FenderBean
Visit FenderBean's homepage!
Find More Posts by FenderBean
View iTrader Profile
