RCU Forums - View Single Post - Royal Ki-61 Build
Old 02-05-2020 | 11:45 PM
EF
That’s how I would interpret it but from the photo it seems your line on W11 is slightly off center at the TE.
I’d suggest you carefully sand the aft ends of the ribs to a fine point (they have a slight square edge currently due to the cutting process probably) and then ensure the line is very accurate. It’s all in order to avoid building in a twist in the wing.
