Deans marine updates
Hi Modellers
I thought that you might like an update from Farcet and to let you know what is new to the DEANS Dear Editor
I thought that you might like an update from Farcet and to let you know what is new to the DEANS MARINE range.
Many modellers do not seem to be aware of our huge range of specialist brass propellers, an example of these is the 163- range of Warship / Destroyer propellers made for our warship range in sizes from 20mm to 55mm made with a supercavitating centre boss, polished and balanced. Also a picture of a selection of the other styles we carry in stock. The full range can be seen in our online shop under the Raboesch label
MINI NYLON HI SPEED PROPS
A range of Hi efficiency left & right handed nylon propellers fitted with a brass 2mm insert to fit our standard mini shafts, Ideal for fitting in the mini gear and micro –gear radio controlled plastic kits or our range of Compact kits sizes 14 16 18 21 23mm dia.
COUPLINGS
We have nine different types of universal couplings, from miniature to heavy weight, all with plug in ends of various sizes, far many to list but all in our online shop.
picture to follow when allowed
Regards
Ron
