RCU Forums - View Single Post - Braking with Elevators Set up
Old 02-12-2020 | 02:51 PM
camss69's Avatar
camss69
My Feedback: (46)
Originally Posted by BarracudaHockey
Not sure with that radio but on Spektrum and CORE I setup a mix controlled by a switch that turns the mix off with the gear up, then from mid elevator to full down progressively applies the brakes until full brakes are full down elevator. I don't like taking my fingers off the primary sticks when landing and looking for a button or slider.
Mine are the same way, I have a mix that disables when the gear are up. When the gear are down mid-stick is no brakes, full down elevator is full brakes. The only problem with this is if you really have to get on the brakes, you are probably moving pretty fast still which means down elevator could be lifting the rear tires, the ones that are supposed to be doing the braking.
