RCU Forums - View Single Post - Kingtech G2 failsafe
Old 02-14-2020 | 04:11 PM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by rhklenke
OK, Marty does know all of that. The issue is that the KT manual does not include instructions as to how to setup the "out of range" failsafe option, nor does the Kingtech GSU have a display that shows that the ECU has detected a failsafe. Either one of those options would tell Marty that the KT ECU actually has the failsafe 2 second delay functionality, and that he's accessing it correctly (Jetcat GSU's have had a "failsafe" display since forever, and newer JC GSU's have one now).
What he's saying is that the only way he has to verify that the ECU has entered the failsafe condition vs. just a normal shutdown is to actually run the engine and turn off the transmitter. If the engine shuts down immediately, either the ECU doesn't have a failsafe mode, or he's not setup his throttle failsafe correctly to access it, but if it delays (at idle, ideally) for 2 seconds and THEN shuts down, he's good to go...
Bob
ps. Just to further elucidate, earlier "Xicoy" ECUs (like those used by older JC engines) did not have the "out of range mechanism" you describe or actually, any failsafe mode, so all you could do is failsafe the throttle channel to go to shutdown mode - with no delay. Jetcats have always had the "out of range mechanism" , Jet Central has it now, so the question is, does KingTech have it?
Yes I'm aware that the older Jet Central ECUs didn't have this and I think I mentioned that unless I edited it out of my first post. However I have said several times that Kingtech DOES have the out of range mechanism, I have said multiple times that I use it and I've said multiple times that I've tested it and I've said multiple times it shuts the turbine down properly and logs that it was shutdown by lost RC. I own 3 Kingtechs that use the G1 ECU and 2 that use the G2 ECU and they all work as described.I guess you guys must think I'm either stupid or a lair, either way, best of luck in the future.
