RCU Forums - View Single Post - Kingtech G2 failsafe
Old 02-14-2020 | 05:56 PM
Afterburners's Avatar
Afterburners
Originally Posted by wfield0455
Yes I'm aware that the older Jet Central ECUs didn't have this and I think I mentioned that unless I edited it out of my first post. However I have said several times that Kingtech DOES have the out of range mechanism, I have said multiple times that I use it and I've said multiple times that I've tested it and I've said multiple times it shuts the turbine down properly and logs that it was shutdown by lost RC. I own 3 Kingtechs that use the G1 ECU and 2 that use the G2 ECU and they all work as described.I guess you guys must think I'm either stupid or a lair, either way, best of luck in the future.
Ok, let's not go there. I appreciate everyones help. I believe I got it working earlier today but was in a rush(Valentine's Day dinner) so I didn't have time to post. I know I did this already yesterday but I think I may know why it didn't work and I will check tommorow. So I am using an AR Smoothflite and I believe it was Len who asked me to check about setting failsafe in the Smoothflite yesterday or the day before and it didn't seem to change things. I had "learned" the ECU with throttle from -100 to +100 and then extended my endpoints and set failsafe in the Smoothflite to somewhere around -125. Today I believe I maxed it out to -140 and now when I move trim up to start and the GSU shows "ready" and the blue LED turns on, the GSU will change to "TH Off" and the LED turns off when I turn the TX off. Yesterday there was no change when I turned the TX off so I think I needed to go further out of the learned range. Will check on that. Sunday it should be in the 40's here so I will do an actual start and turn off the radio and see if goes to idle for the two seconds before shutting down. Also interested in seeing if it shows a failsafe or if I have to go into the logs to find out. Thanks again for everyones help.
