RCU Forums - View Single Post - Sig Citabria Build
Thread
Sig Citabria Build
02-16-2020, 05:10 PM
206
Starwolf2
1 Post
I added the red Monokote to the other side of the wing today. I started out using the same method as yesterday. I first tacked the covering on the bottom of the wing. Then, I used the iron to secure the perimeter of the covering and rolled it over a somewhat straight part of the wingtip. Next, I cut several strips to use as tabs to pull out the covering as I heated it with the dryer and pulled it around the curved portions of the wingtip. I was pretty satisfied with the end result.
Finished securing the perimeter.
Wrapped the covering around a straight portion of the tip and cut "pull tabs."
Top of the wing after I finished the bottom covering.
The bottom of the wingtip.
Reply
Like
Starwolf2
View Public Profile
Send a private message to Starwolf2
Find More Posts by Starwolf2
View iTrader Profile
