RCU Forums - View Single Post - Kingtech G2 failsafe
Old 02-17-2020 | 08:07 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by Afterburners
I believe the "Diagnostic Messages" screen would have given me the failsafe notice but like I said I didn't see that in the manual until after I had cycled the ECU one or two more times and I think the info of last shutdown is wiped if you don't get it on the first re-power up after the failsafe shutdown. The "Summary" screen only will give you running info of the last four runs and an abnormal code line if something happened. I think at this point, I would need the ability to download the ECU data to my PC to see the failsafe although I will check the summary again and see if it kicked a code of the failsafe run. I don't think there's a list of codes in the manual though.
You may be correct about the diagnostic menu as I've never actually looked at it myself and honestly wasn't aware of it until you mentioned it. Still, the Summary menu has the basic info, including shut down reason, for the last 4 runs. Also, I believe that's literally "runs", not ECU power cycles.
