RCU Forums - View Single Post - Kingtech G2 failsafe
Old 02-17-2020 | 01:42 PM
  #31
Afterburners's Avatar
Afterburners
Originally Posted by wfield0455
You may be correct about the diagnostic menu as I've never actually looked at it myself and honestly wasn't aware of it until you mentioned it. Still, the Summary menu has the basic info, including shut down reason, for the last 4 runs. Also, I believe that's literally "runs", not ECU power cycles.
I think the diagnostic menu is only accessible on the first reboot (power down and up) of the ECU after a run cycle which is similar to the old Xicoy ECU's. As for the summary menu I just checked. I only have four runs total on the engine and the 3rd was the one where I turned the TX off while the engine was running to simulate a F/S. Other than every run having different numbers in the "AbNor" row, under the "AbNor" line each run there is another row that just says "User Off". All four of my runs just say "User Off". On Pg 57 of the manual they mention a PC terminal interface available in the future that would be able to give more detailed info. I don't see a PC interface cable on the Kingtech website.
