Originally Posted by
dork_blaster
Thanks Smokey - hope it all helps in the end.
Here's the final canister install, next up is finishing the motor box, mount the motor, make the headers, mount the fuel tank, install the Powerbox and radio, install the throttle and choke servos, put it all together and fly it!
Note the offset in the cans (about 1/2in). This is because of the cylinder stagger of the engine. The right thrust reduces it slightly (more or less depending on how close or far you mount the cans). Since the nifty mounts from RC Showcase were mounted at an angle and flush against the wall rather than sitting on top of former, I added a small screw to keep the mount from rotating.
what length are those canisters ?
