Flaps
Yes, on one of my '47s the same problem exists. Has to be something that CARF did that was slightly off when the holes were drilled, etc.
My other 47 is fine.
What I did is just sort of split the difference and do the best you can with alignment by using the subtrims and travel on the radio.
For what it's worth, my older model is the one with the issue, so maybe it was corrected on later runs.
-Mike O.
