Originally Posted by
winter1
Ok guys. I'll try both options. Then I'll let you know which one I chose. Each option has its advantages and disadvantages. A - more comfortable operation. Risk of high pressure on the front wheel. B - less comfortable operation. No impact on the front wheel. Thanks a lot. If anyone has any other suggestions - here with them.
***winter***
There is another option (that has not been mentioned here) that I've read about elsewhere: using the accelerometer function in Jeti radio to activate brakes. Instead of using a slider or up-stick mix you simply tilt the transmitter to activate the brakes. From what I understand it is proportional, but you would have to make sure you are not tilting the transmitter at touch down otherwise you may inadvertently land with the brakes pre-locked. I like the idea of this method more so than using a slider because the last thing I want to be doing right during one of the most intensive parts of the flight (touch down) is fumbling to find the slider to apply brakes. I understand this would not be an issue for those of you with runways long enough to have the time to transition to the slider for braking, however that is not the case for me as our runway if very short, so getting to the brakes quickly is imperative. I think I'll play around with this the next time I'm out at the field and at least try it out with some high speed taxi. - Tom
