RCU Forums - View Single Post - TopRc Voyager build
Thread
TopRc Voyager build
03-01-2020 | 06:38 PM
11
sysiek
My Feedback: (
176
Feb 2009
2,363
Chicago , IL
Ok so this weekend, the fuselage is all together, the aluminum alignment tubes are glued to the rear section,and all the servos pushrods installed, the note please use the 3mm tap to re do the plastic ball connectors the almost impossible to do with just the pushrod, and use 3mm drill for all the glued horns maybe before glued them to the surfaces, the jets is actually very cool and is very compact the jet could be transported in two main elements back and bigger front with turbine and all the stuff to make it rtf the back will be just the rear fuselage with pipe and 3 servos cables for elevators and rudder, I’m planning to use the electrodynamics plug for 3 servos to make the separation much easier.
Reply
Like
sysiek
View Public Profile
Send a private message to sysiek
Find More Posts by sysiek
View iTrader Profile
