Originally Posted by
kohersh
that's interesting different than any setup I;ve ever run or seen before. So just for the sake of asking, do YOU split your 3S life 9.9 Turbine pack into your ECU on a JR/servo 3 pin plug" and also the Deans plug into the ECU? ie...you don't supply any RX power to your Kingtech pieces.
These G3's are new territory for me with fewer connections and wires, but the G1 and G2 the 9.9 pack was only for running the pump and starter motor. Everything else, including the ECU (and a GSU if present), was powered bye the bus voltage on the throttle port, wasn't it?
Thats why when learning the RC signal on a kingtech, you unplug the 3S or your motor would spool during stick up setpoint
Yes, the 3S LiFe powers anything KingTech. The 2S powers avionics (RX/Servos). Maybe this will help:
