Thanks, guys. I do have a purpose built CG balancer, but for some reason I have more trouble with it than using my pointers. I will put it to use again until I get used to it. So, just clarify, if the nose of the plane rises lowers & the tail lowers then I have a tail heavy plane & the necessary weight shift with the pack or adding a tad of lead in the nose will be required? Or, do I have it backwards? Thanks, again for your help.
S/F,
Masterguns
