I’ve never seen a rudder servo wheel like that used on a pull pull
How does it work and who makes it?
Hi Itc
The advantages of this type of installation are:
- If installed correctly you get an equal tension on both sides of the installation (works with a single cable opposite one to the left and the other to the right).
- More linear rudder movement with benefits in centering.
- Less servo force (resulting from distributed tension).
But with a normal servo arm it still works!!!!!!
You can find it in here:
https://www.probuild-uk.co.uk/index....roduct_id=4147
https://www.ebay.co.uk/c/1052995784
https://www.gravesrc.com/hangar-9-pu...air-large.html
