Hi Fenderbean,
I'm in the final setup of my F22 before the maiden, but I have a major issue with interferences of RPM between the two Merlin 166TS.
And yet I have a Mu-metal plate between the 2 turbines, but it's not enough.
In my F18, with 2 Merlin 200, the Mu-metal plate was the solution, but it seems that the 166's are much more sensitive.
As you have exactly the same engines and same setup, did you encounter the same problem ?
Thank you.
Arnaud
