Hi Arnaud, you need to rotate the engines so the motor RPM sensors are not pointing at the other motor. I discussed this with Gaspar and my test run showed no signs of cross talk. I will post the correct position once I can find that email.
to make it easier can you post a picture from the front of your engines please?
