RCU Forums - View Single Post - Newby needs help
Old 03-24-2020 | 12:49 PM
Hydro Junkie's Avatar
Hydro Junkie
Okay, after doing some web surfing, what I found is that it's sold by Offshore Electrics here in the US. If you contact OSE, they can set you up with everything you will need. As far as radio gear, I use a Futaba 4PLS for my boats. Any two or more channel radio on 2.4GHz or 75MHz can be used with your boat. I'd also recommend using a servo with no less than 90 inch ounces of torque
Sloman31 (03-24-2020)
