How about bearings that reach a speed of 130,000 rpm (with oil) and utilise ceramic balls? Are these good enough? And I've noticed from different manufacturers that the lower the contact angle, the higher the rpm speed (with oil) so given that this is correct, I should go for the bearing with the lower contact angle?
