Originally Posted by
trroadster
Hi
I just picked up a partially built kit/ The tailfeathers are built and covered but I can scan at actual size and send them to you. In return I would ask for info re the servo mounts and pushrods in the fuselage. Also, does the plan show flaps or jusy ailerons?
Don
Plane has both flaps and ailerons. Flaps have a single servo mounted mid wing. I will check but should have the plans.
