Added formers (?) triangles to the wing tips, To get them ready for covering. These will carry the film with out sags.
Then I hung the ailerons. I needed them on so I could match the rear of the wing tips to the ailerons taper.
I added some Bass fill to the bottom of the L.G. blocks so they would be flush with the bottom of the wing . I will need to add a fill to the L.G. wire slots so as to now raise the wires flush with the bottom of the L.G. blocks.
The it was time to patch all of the holes in the bottom of the wing, some I (most) made and some already there. Tedious and frustrating at times. But I got all but one at the wing tip done and rough sanded. Will do some putty work. And the whole center wing section will need to be glassed.
Ken
