Disconnect the RPM telemetry and give it a try.
Also make sure your plug cap is tight, if you don't see the outline in your hand for an hour after pushing it on its probably not tight enough.
Next is vibration, check out the lights on the remote receiver or receivers, wiggle the wires for the remotes and see if the lights go out or flash.
