DA50 w/ New Ignition & Header
Used but still runs strong. Comes with brand new never used ignition, flex header, standoffs, and two exhaust gaskets. Serial # 6952. Never been crashed or had prop strike. $350.00 shipped to lower 48.
Two notes:
1. Cylinder head fin has small 1/16" hole drilled into fin near spark plug used for safety wiring plug cap which is not required.(Visable in pics)
2. Center prop nut/shaft has been shortened a little. This is of no consequence. Shaft still extends beyond prop/spinner into prop washer but does not go all the way through. See pic with Tru-turn backplate and Mejzlik prop.
