Just a final couple detail peices to attach on my F4. I added the plates that move with the stabilator and they look great. It was easy to add the screws on top for the side peices. The bottom is another story. It looks like I need to remove the stabilator and the line up everything and then drill the holes. Then reassemble and install the final screws in the lower hatch. Is this how it is done?
Also, how are you mounting the tail hook? It needs to be removable in order to remove the lower hatch.
Thank you,
Jeff
