Originally Posted by
Edgar Perez
Getting to the point where the plastic canopy need to be cut to glue them to the canopy frames.
There are no marks in the plastics canopy to indicate where it needs to be cut, so I guess need to eyeball it.
Any ideas or recommendations on this part of the build?
I am sure yo know it already. I would lay it over the frame. then mark large and cut, then you can trim little bit at a time when you try to fit it on the inside. that way, there is no chance to mess it up. I hope this helps.
Behzad
