Originally Posted by
ECHO24
From this footnote in the NPRM, I expect the first thing the FAA will do is require all aircraft with BVLOS
capabilities to operate under standard remote ID at all times, and only allow FPV at approved fields in
tightly controlled closed-course flying like drone racing.
"While this proposed rule does not propose any changes to requirements related to beyond visual line of sight (BVLOS) operations, the FAA intends for the rule to be dynamic to account for future changes related to line of sight operations. The FAA specifically notes that this rulemaking requires UAS without remote identification equipment to always be operated within line of sight."
- and only at FAA-Recognized Identification Areas.
Yep. Pretty clear the walls are closing in on non-RemoteID LOS ops. First drive them all to FRIAs, then FRIAs go away over time, and pretty soon if it flies, it has to have RemoteID.
