RCU Forums - View Single Post - Simple Commercial Buoyancy Engine
Old 04-21-2020 | 04:43 PM
subnewbie123
Hi airsteve172,
Thanks for response. I've had a look at some compressed air systems. Some use not a compressed air cannister, but just use the air from the water-tight chamber, causing a low pressure cell. We've also had a look at some peristaltic pumps as well but not sure that they could withstand pressures at lower depths, especially given the size we're meant to be restricted to (150mm diameter cylinder).
