RCU Forums - View Single Post - Datum/Referance Line
Old 11-07-2003 | 05:40 PM
William Robison
Default RE: Datum/Referance Line
NGH:
If you are worried about it, the stab will probably be a couple degrees negative relative to the wing. And the engine either neutral or a slight bit down also.
Go here:
http://www.rcuniverse.com/forum/Wher...1063414/tm.htm
Post #5 explains the interaction of incidences and thrust line in fair detail. Should take care of your questions. If not tell me what's not yet clear.
Bill.
