Stick and fully 3D capable don't work in the same sentence. Quad flaps can be added to most any design. The Capiche 120 should be nice but hard to aquire in the states. I would suggest something for the Saito for unlimited vertical and in the 72" span. Take a look at the CA models Extra 27% as it should have all you are looking for. The wings and tail surfaces come sheeted and the fuse is laser cut and can be assembled in a weekend. Cut the ailerons in 2 sections each adding servos for the quad flaps (I don' think this is necessary however). A new distributor is being set up in Florida.
http://www.marcelocolombo.com.ar/Ingles/homeingles.htm
Good luck,
EXCAP232
