Originally Posted by
srp55
David it depends on what ignition box you have. The black high hat version is a 4.8-6.0 volt. There are two square box ignitions one is a 6 pin connector (RED) the other is an 8 pin connector (BLUE) both will except any 7.4v 2S battery. Check Vogelsang Aeroscale web site under Moki parts I believe they explain it better then I. As for a battery I use a 3800 mah Life battery. What do you have your 180 in.
Steve
