Looked at the "spare" carb. The hole in the brass part was so offset from the nipple bore that I could only get the very tip of a T-pin into the opening. Almost impossible to blow through the opening. Used the nipple as a guide and carefully opened the hole up to 1.7mm. Stashed it away for later. Also found an idle needle for that engine in the box. Any thoughts about it?
