The 3D PDF format doesn't support textures, but i found a way to export the model in 2 different paintschemes for your viewing pleasure
The files are too large to attach here, so i uploaded them on Google Drive.
When opening the 3D PDFs, an Options button will show up in the top bar, just click it and choose to trust the document (any of the 2 options there). You may need to click on the screen one more time for the model to show up.
For best results, do the following:
- Right click on the screen, go to Viewing Options > Use Perspective Projection
- Right click on the screen, go to Viewing Options > Lighting Schemes > CAD Optimized Lights
- Right click on the screen > Full Screen Multimedia
You can use Left mouse button to rotate the camera, Ctrl + L Mouse to pan, and Shift + L Mouse to zoom.
If the model is not displayed correctly, right click on the screen, go to 3D Preferences, check box labeled "Enable double-sided rendering".
https://drive.google.com/open?id=1jz...t29n40I15RKgHa
https://drive.google.com/open?id=1YQ...irkSXX_1iMJXYK
