Incidence Challenge
Turns out the issue was with the incidence. With the shim installed on take of, I now needed to input up trim in order to attain straight and level flight. All the down trim that was previously introduced for straight and level flight prior to the shim being installed was removed. Unfortunately, I was only able to complete one flight. The next flight will be without the stick-on-weights.
Until next time, enjoy smooth landings.
DaleD
