RCU Forums - View Single Post - Jet Central Rhino 160 propane start RC jet turbine engine
Old 05-26-2020 | 10:21 PM
RCUser012
Guest
My Feedback: (73)
Default Jet Central Rhino 160 propane start RC jet turbine engine
This is back from repair a few years ago. The aircraft rear end caught fire on the ground and sooted up the rear of the engine. Jet central replaced the case, and a bearing change was also done at the same time ... The engine has somewhere around 10 - 14 hr on it total. I do not have the EDT to check. The engine spins over very smoothly, and is in very good shape, and comes with everything pictured - ECU - Pump - solenoids, electrical connections. I'm not even sure who runs Jet-Central these days or does maintenance for the , so you may need to tinker around to get all sorted out ( reflected in price )
Shipping $40 in the USA in case pictured.
RCUser012 is offline
