Provides the tightest possible in-cowl installation.Designed for use with O.S. 61SF and 61FX 2-stroke engines.
Header: 2-3/5 Long
Wide
Length of exhaust opening at engine 1
Height of opening at engine 3/8
Distance between mounting hole centers: 1-11/16
No Silicone coupling included
9/10 OD**NOT for 91 sized 2-strokes w/ TF muffler (too restrictive)****
In-Cowl Muffler for Top Flite P-40 and P-51 Gold edition.
ALSO 3.5x50mm or 6-32x2 screws (or use screws supplied with engine)
This also works for the Magnum .65 engine and the O.S. .60FP engines.
DO NOT attempt to use this header/muffler combination js12/8/93
on the 91FX. ir/jl
This header will also work with the .75AX (OSMG0575)
9/9/8 GX
This will also work with the .65AX ABL (
OSMG0558).
Regular $15.95 mine $9.95
Send me you name and address in order to [email protected] for Pay Pal payment. I do not take oders out of the US or accept money order but well accept personal checks. Let me know if you can use this header.
