The ds-24 also has haptics and tx accelerometers.
Probably the biggest advantage of Jeti is the “duplex” part. Each satellite is its own FULL rx and when you pick “dual path” output the transmitter is like 2 transmitters and it is talking to both rx’s at the same time. The system is then constantly picking the best radio link.
You can do this with any rx! The smallest rx I have set up as “dual path” is a 12 channel rx. But I don’t see why you couldn’t do it even with the smallest 3 channel rx! All of this happens in 2.4.
As I understand it, if the 2.4’s ever had a problem, the tx and rx then switch to 900 and this is constantly and seamlessly done.
Having a solid link with our airplanes really is what it’s all about and jeti delivers over and again.
