Since my last post, I finished all the electronics installation. Since I switched to the Jeti DS12, I cut a third electronics tray layout to reconfigure the installation.
The setup consist now of the Central Box 200 and two R3 receivers. I also slightly modified the UAT tank sitting.
Still in the process of completing the setup.
Next is to setup the airspeed sensor. I machined a small unit that uses a Dremel 1/8" aluminum collet. All seems to hold pretty well once the cap is on.
