Originally Posted by
Woketman
OK, then I assume that if you run a 14 or 18 ch RX as RX1, and plug most if not all servos into it, how do you add other RXs? Is it using some sort of data cable? So you have everything plugged into RX1 and you have RX2 and RX3 as satellite RXs? So RX1 and RX2 can be 2.4 and each function as a dual path? And then RX3 can be the 900 MHz backup?
Thanks guys for helping me figure this out.....
I have done exactly this with an 18 channel Rx with Ann R3 as a satellite rx. The R3 plugs into the 18 channel Rx and I assign the channel it’s plugged into to see the R3 and then run dual path.
All my servos and stuff are plugged into my 18 channel Rx.
