Although the website catalog on page 23 of 28 also provides a "3PK 75MHz FUTL8905 3PK FM Synthesized" transmitter module, I've either missed it or the catalog doesn't show a synthesized receiver module other than the 9-Channel PCM (R309DPS). Is there a synthesized receiver for the Futaba T3PK or will I be forced to purchase receiver crystals even if I get a synthesized transmitter module?
I'm wondering since I also own the JR XS3 Synthesized pistol radio and four of the RS300 Synthesized FM 3-channel receivers--the RS300 receivers are larger than most which required some modification to make "fit" and/or are exposed in the smaller R/C vehicles. It also appears that the 9-Channel R309DPS receiver module is wider and higher than most of the others listed as well as longer than the Futaba 3-Channel receivers.
BTW, I've asked my LHS to check into the AM conversion module, which I heard was on back order, so I can run my Mini-Z's with the T3PK instead of the stock Mini-Z radio.
http://www.futaba-rc.com/sellsheets/...03-catalog.pdf
http://www.futaba-rc.com/radioaccys/futl26.html
Thanks.
