Originally Posted by
Mike Pascale
Need help to install front mount on himax
hc 63 i have conversion kits for motor
But can't figure out how the front support is attached.
Hi Mike..
I did the conversion, and it mounted with no issues. Once you figure it out, watch the motor temperature. I found that mine ran significantly hotter when front mounted. May not be an issue on your application.
Gary
