Hello everyone, new to the forum.
i have a bit of experience with RC toys but every now and then there is an issue that you need expert opinion on.
i am having connectivity problem with the battery connector on my sons rc truck, usually i just switch the connectors to xt60 for ease of use, but this specific battery is a (Li-ion Fe) and the connector is strange a 6 hole connector which resembles a tamiya connector.
i have 2 similar trucks, the other one i already modded and changed the connector to xt60 to use with a 3s lipo i have, but this 2nd one i would like to use the stock (Li-ion Fe) it came with but just need to change the connector to a xt60, any advise about the wiring would be great, usually on batteries there is a negative and positive wire but as i explained above and as you can see in the picture this one has 6 pins so i am not sure which wire to solder to the xt60 and which ones will be useless to wrap in heatshrink
attached picture of the battery and its connector hxxps://ibb.co/1R7y9P0
thanks everyone
